on 11-02-2024 01:37 PM
Fibres been down since Thursday pm, no lan light on box, only power and a flashing WiFi light, eero pro router has steady red, please help!!!
on 15-02-2024 09:21 AM
If city fibre have acknowledged an outage in the area, this will affect a number of circuits and they will be working to repair this.
on 14-02-2024 06:07 PM
Hi Chris, I’ve checked the box connections are all good. I’ve been speaking to tech support daily with still no resolution. I happened to run into a city fibre team outside the house this morning, they weren’t investigating my case but said that a cable had been damaged by some building work in YO31 postcode so grateful if you could add us to the list for repair!
on 12-02-2024 03:01 PM
Hi Weston2080,
Could you check that the cables are seated correctly in the ONT. If they are then I'll pass this over to our Future Fibre team for further investigation
on 11-02-2024 09:48 PM
Thanks, in that case, I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
on 11-02-2024 04:52 PM
Full fibre 900
on 11-02-2024 04:04 PM
The Ethernet light is on, I thought that you said it was off. This looks to me like a fibre fault to me. What service are you on full fibre or G.Fast?
on 11-02-2024 03:57 PM
These are the lights, tried 30 min off and cables
on 11-02-2024 03:51 PM
on 11-02-2024 02:48 PM
If the other lights on the ONT are correct, that is not the fibre but an issue between the ONT & the Eero. Have you tried powering both off for at least 30 mins & if still bad, change the Ethernet cable between the two?
