Dual Band, 2.4GHz?
lh123456
Message 4 of 4
I have recently been sent a new router.  Since upgrading to the new router and full fibre, I am no longer able to connect with my robot hoover as apparently this requires a 2.4GHz connection (rather than a 5GHz one).
Is the router that I have been sent dual band?
And if so, is there a way that I can join to the 2.4GHz connection in order to connect with my hoover?
Many thanks
3 REPLIES 3
Message 1 of 4
our help article here will show you how to log in and navigate to the Wi-Fi settings :
Change your wireless channel - TalkTalk Help & Support
Message 2 of 4
How do I log into the router? How to I separate them into 2 separate Wi-Fi channels?
thank you
Message 3 of 4
All our routers are dual band with both 2.4 and 5Ghz Wi-Fi
If you have a device that is having difficulty connecting you can log into the router and separate the 2 Wi-Fi channels by giving them separate names,  something like Home2 and Home5 so you can tell the difference between the 2 channels when trying to connect.
