20 hours ago - last edited 10 hours ago
Can TalkTalk provide eero Pro 6E or Wifi7 router with Fibre900?
The current eero pro 6 is not capable of maintaining the fibre900 speed.
Waste of money, if customer is paying price of Fibre900 and getting speed to Fibre500.
Can someone technical from TalkTalk take a decision on this one?
Thanks!
Wired speed test on laptop connected with eero, huge disappointment.
an hour ago
This is with eero Pro 6 over ethernet with TalkTalk. Try connecting a wired device directly to the the LAN port on the ONT and see what speed you get then.
7 hours ago
Hi @ferguson
Correct, I have same expectation of at least 900Mbps. But its no where near.
Can you please share information about:
Are you with TalkTalk, if not then which service provider?
What router you have?
Were you connected with cable to router directly while this speedtest?
Thanks!
9 hours ago
That's odd. I would expect to see wireless results at around that level. But not wired, this is what I get:
10 hours ago
I'm sorry but we are unable to provide a different router
10 hours ago
Today I have Cat8 Ethernet cable delivered. I was hopping that this will change things but no difference. I just tested it and still the same.
Upload is even worse. Download varies massively from 300 to 650ish something.
speedtest02
Speedtest right now from eero pro 6 itself.
speedtest03
The only solution is better router is required. I myself working in the industry. So I know what is the issue.
16 hours ago
Hi bitrate,
If you'd like us to take a look at your speeds can you please update your community profile to include your:
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
