Fibre900 needs eero Pro 6E or Wifi 7 router
bitrate
Newbie
Message 7 of 7
Can TalkTalk provide eero Pro 6E or Wifi7 router with Fibre900?
The current eero pro 6 is not capable of maintaining the fibre900 speed.
Waste of money, if customer is paying price of Fibre900 and getting speed to Fibre500.
Can someone technical from TalkTalk take a decision on this one?
Thanks!
Wired speed test on laptop connected with eero, huge disappointment.
6 REPLIES 6
Message 1 of 7
This is with eero Pro 6 over ethernet with TalkTalk. Try connecting a wired device directly to the the LAN port on the ONT and see what speed you get then.
Message 2 of 7
Hi @ferguson
Correct, I have same expectation of at least 900Mbps. But its no where near.
Can you please share information about:
Are you with TalkTalk, if not then which service provider?
What router you have?
Were you connected with cable to router directly while this speedtest?
Thanks!
Message 3 of 7
That's odd. I would expect to see wireless results at around that level. But not wired, this is what I get:
Message 4 of 7
I'm sorry but we are unable to provide a different router
Message 5 of 7
Today I have Cat8 Ethernet cable delivered. I was hopping that this will change things but no difference. I just tested it and still the same.
Upload is even worse. Download varies massively from 300 to 650ish something.
speedtest02speedtest02
Speedtest right now from eero pro 6 itself.
speedtest03speedtest03
The only solution is better router is required. I myself working in the industry. So I know what is the issue.
Chris-TalkTalk
Message 6 of 7
Hi bitrate,
If you'd like us to take a look at your speeds can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
