This post is a little old and may not be relevant anymore…
Old post notification
Full Fibre 150 installed yesterday
Barrowman
Message 31 of 31
Hi folk, I hope someone can help this 79 year old understand why when I had fibre 65 copper wired to my house I had better wifi all over the house than I do now I have full fibre.
Yes I do have 150mb download speed in my lounge but everywhere else it drops down to it's lowest reading of 1.4mb in my conservatory where my wife sits in the afternoons. With my fibre 65 I used to get around 32mb speed in the conservatory - now it's virtually nothing and makes it impossible for her to watch anything.
Any comments appreciated, thank you.
Barrowman
30 REPLIES 30
Barrowman
Message 21 of 31
Hello again support team.
Update...... The system worked well for a week after installing the second eero it constantly gave me 151 mbps but now it's gone downhill as you will see if you check my online speed checks.
The first speed check I did today was, download 58 mbps and 29 mbps upload, the second was 83mbps and 29mbps,  I've just done a speed test on my iPhone and it's only 38 Mbps.
Tried to do your online connection test and it wont let me do one for some reason, in fact the only thing it will let me do is the speed test nothing else. Any comments, surgestions or anything else you can do to remedy this issue would be appreciated.
Thank you.
Barrowman
Message 22 of 31
I'm really glad to hear this and thanks for confirming 🙂
Barrowman
Message 23 of 31
New eero arrived yesterday, all appears to be working fine now its set up...
Thanks for your help Karl.
Barrowman
Message 24 of 31
No Problem 🙂
Barrowman
Message 25 of 31
Thank you Karl
I will look foreward to that and hopefully This old fella will be able to set it up okay. Thanks again.
Barrowman
Message 26 of 31
OK, I'll get a second eero out to you, to use to extend the wifi signal and see if this helps with the signal coverage within the home.
Barrowman
Message 27 of 31
No, no powerline adapters or wifi boosters, to be honest I'm not even sure what they are....
Barrowman
Message 28 of 31
In the previous setup, did you only have a router, or did you have powerline adapters or wifi boosters in place ?
Barrowman
Message 29 of 31
Yes, it was replaced with an eero6 supplied by TalkTalk along with a voip box for my landline.
Barrowman
Message 30 of 31
Did you replace the router when you had fibre 150 installed ?
Anonymous User
