on 20-11-2023 07:49 AM
Good morning,
We're due to have a full fibre 150 installation today 21/11 but we have not been sent an EERO router - no emails no tracking or anything. Also we were told a box would be installed on the outside of our house prior to our installation date but this hasn't happened either. I was called last week and I did flat this to the person but still nothing.
Would someone be able to check what's going on for me please?
Thanks so much for your help.
Kaz 😊
on 07-12-2023 11:48 AM
Let us know what happens today.
on 06-12-2023 08:32 AM
Good morning,
I had a text yesterday to say the engineer is still coming tomorrow (7th) but we've not been sent a router. Please can you look into this for me and advise if the engineer needs to be rescheduled ?
Many thanks.
Kind regards,
Karolyn
on 05-12-2023 12:27 PM
I will see what I can find for you.
on 04-12-2023 05:59 PM
Hi Arne,
Just had an update via text that says -
'Hello we've found a problem with your order. Our supplier needs to do some more work before we can get you connected. Don't worry we'll continue to work hard in the background to get you connected. We'll update you on 11/12/2023.'
We were meant to be having an engineer round to install this week on the 7th. Would you be able to see if you can find out what's happening please? Take it they won't be coming in the 7th?
Thanks so much.
Kind regards,
Karolyn
on 01-12-2023 08:53 AM
Will do, thank you Arne.
on 01-12-2023 08:52 AM
Post back when the install is complete.
on 01-12-2023 08:24 AM
Thanks so much Arne.
on 01-12-2023 08:23 AM
Thanks for the update, the Eero will arrive before the install date.
on 01-12-2023 07:23 AM
Hi Arne,
Had a text message this morning to say engineer is due on the 7th Dec between 1pm and 6pm to connect the fibre cable now installed outside to the inside of our house. Do we need to be sent the eero router now as we haven't got that yet?
Thanks Arne.
Kind regards,
Karolyn
on 01-12-2023 07:16 AM
I will see what I can find.
on 30-11-2023 05:16 PM
Hi Arne,
Thanks so much. Openreach have just turned up to feed the cable into the duct outside our home. We didn't know they were coming but guess it's good news they are doing something! 😂
Following this would you know when the engineer will be here to install into our home?
Many thanks.
Kind regards,
Karolyn
on 29-11-2023 02:46 PM
I have asked for an update
on 23-11-2023 01:51 PM
Hi @Kazp_1
the update says
"Unfortunately we have identified a potential issue on site. We are waiting for a suitably skilled engineer to complete the external work . We apologize for the inconvenience and are trying our best to complete this work as early as possible. Our Next review will follow on 28/11/2023."
We will need to check after the 28th.
Sorry
on 23-11-2023 09:30 AM
Hi Kazp_1
Sorry that you are having problems
I will ask for an update.
on 22-11-2023 04:37 PM
Hi Michelle,
Nothing has happened, no engineer visit. On chat I was just told the order isn't going ahead, but no explanation given so I'm not sure why.
Many thanks.
Kind regards,
Kaz
on 22-11-2023 01:10 PM
I'm sorry for the delay. How are you getting on?
on 20-11-2023 09:40 AM
That is quite normal, the installer normally brings it with them. The box you refer to is also done by the installers on the day, they bring & install everything & should test it all, before leaving your property.
