on 19-02-2025 10:47 AM
I had full fibre and new router installed yesterday.
I cannot login to the router configuration - Network name/password rejected. Although I can connect devices using these details.
on 19-02-2025 11:32 AM
You cannot set a static IP address, that is always done on the device itself. However, I think you mean a DHCP reserved IP address. The address is still automatically assigned, it is just always the same IP address.
To reserve the address that a device currently has, go to:-
Dashboard > Manage my devices > Manage advanced settings
Click on the device in question & use the Device Info tab:-
Click on the Reserve IP button.
To allocate a different IP address to the device, it is necessary to go into the main DHCP configuration at:-
Dashboard > Manage my devices > Manage Advanced Settings > TalkTalk Wi-Fi hub > LAN IPv4
Then click the Add Reserved Address button, in the resulting display, select the device’s name & set the address you want to use.
on 19-02-2025 11:19 AM
Yes! Thank you - with all the hassle of re-configuring everything I had used the wrong password from the back. Although, in my defence the instructions are not entirely clear.
Now I'm in, can you tell me how to set a static IP address for a device ?
on 19-02-2025 10:49 AM
Assuming you have the Safgemcom Hub 2 then you log into it with:-
username: admin
password: (see the router password on the label at the rear of the router, behind the removable lift-up panel)
You may be trying to use the Wi-Fi details to log into the router. If you remove the card from the back of the router, the login details should be behind this.
