Phone not registered on Grandstream
Elisa24
Message 11 of 11
I have followed all the set up instructions, internet works but the phone light on the Grandstream (DVA) is off.  How do I know whether TalkTalk has activated this service (because my copper line is still working).
10 REPLIES 10
Message 1 of 11
Thanks. It looks as though the VoIP order hasn't completed yet. Unfortunately I can't tell when the service will go live but if you contact our customer services team they'll be able to pass you to a dedicated team who'll be able to help
Message 2 of 11
Yes, that is correct.  I have now tried the reset and will leave it for an hour.  If nothing happens I will reconnect to the copper until I hear from you.
Chris-TalkTalk
Message 3 of 11
Just to confirm, at the moment you have an internet connected to the ONT and your telephone is working when connected to the old telephone socket?
Message 4 of 11
thanks, Chris, I need to know if TalkTalk has actually made it live as the copper is still working, and I need an almost continuous service as I am on a care support call list.
Message 5 of 11
Thanks, is it still not working today?
Elisa24
Message 6 of 11
Community profile updated as requested.
Message 7 of 11
Hi Elisa24,
Can you also please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 8 of 11
Yes, it is, which is why I said to connect the Ethernet cable of the Grandstream directly to the ONT in place of the router.
Message 9 of 11
Thanks Keith, but what is the ONT?  Is it the box on the wall that brings the fibre into the house, ie what I plug the "router" (eero) into?
Message 10 of 11
Connect the Grandstream's Ethernet cable directly to the ONT in place of your router. Then perform a reset on the Grandstream. If it all works now, connect it back to the router as normal.
