PlayStation Portal issues
on 02-02-2025 03:28 PM
Message 27 of 27
Hi Everyone,
I switched over to TalkTalk fibre 150 as it appeared a better deal than I was already receiving. Whilst in general the WiFi appears to be okay, there’s still some spots in the house that don’t connect. Most frustratingly, I’ve a PlayStation Portal and the connectivity is non existent. Every 20 seconds or so, the connection drops, no matter where I play. PS5 on the whole, connection is good.
I live in a new build, so the internet box is located under the stairs cupboard. This is approx 20-25ft from the living area and maybe up to 35ft to the spare room where the PlayStation lives, so distance wise I can’t see there being any issues.
When the PlayStation was ‘wired’ in, the connection was 50% better. However, this isn’t feasible for a long term solution.
Anyone able to offer any help / advice as to how I can resolve this?
Thank you! Adam
Labels:
- Labels:
Connection
Gaming
Streaming
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
26 REPLIES 26
on 07-02-2025 09:31 AM
Message 21 of 27
Hi @Adamp02
Can't it work over WiFi, I thought that was the whole point of me trying to help on in post #2.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2025 04:38 PM
Message 22 of 27
Hi @KeithFrench ,
The Eero router itself has 2 ports on the back - 1 which plugs in to the BT Openreach Box and the other is ‘spare’. I assume that the gigabit switch would only be useful if there wasn’t a spare port on the Eero router already? Would your suggestion be that I then somehow trail the wire up through the cupboard and into the room needed?
thank you again - Really appreciate your help.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-02-2025 11:01 AM
Message 23 of 27
You do not need an electrician to add additional Ethernet ports to an eero. You just need to buy a Gigabit switch with enough ports for your requirements, like this example:-
Just connect one port to the eero and all devices requiring an Ethernet connection to the other ports.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-02-2025 08:18 PM
Message 24 of 27
Hi @KeithFrench ,
thank you for taking the time to reply. Currently, both the ONT (BT Openreach box) is wired under the cupboard - The Eero router was also in the cupboard but have moved it outside of the cupboard. I’ve left it here for 24hours, but it hasn’t made any difference to the Portal connectivity.
Reading additional information online, it sounds as though the best practice is for the PlayStation to have a wired connection, which isn’t ideal and would mean getting an electrician/engineer or sorts out to install additional ports.
Do you happen to have any other possible suggestions to avoid this?
thank you again
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-02-2025 07:27 AM
Message 25 of 27
Hi Adam,
How are you getting on?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-02-2025 04:22 PM
Message 26 of 27
Hi @Adamp02
You say that the "internet box" is in the understairs cupboard, but is this the router or ONT? The router MUST be out in the open.
Which make/model of router do you have?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
