Telephone Line Stuck In Engaged Mode
TaffStrat
Message 33 of 33
Hi guys, hopefully I can get some “pointers” or assistance with a telephone problem? I’m using Full Fibre with a Grandstream box to link the telephone line… unfortunately, it appears to be stuck in engaged mode, preventing both incoming and outgoing calls to our home phone. I’ve already unsuccessfully tried rebooting the Eero and reseting the Grandstream… the telephone (blue) light on the Grandstream is continuously flashing and the telephone handset just gives out a continuous engaged tone! Our internet signal is unaffected!
Does anyone have any more ideas for me to try please???
Brian Chaloner
32 REPLIES 32
Message 1 of 33
Hi TaffStrat,
ah no not at all. I wasn't sure what the blinking light meant either, I had to look it up. Please let us know if you need anything else.
TaffStrat
Message 2 of 33
Thanks for that Debbie, we've just checked that and there was an unanswered voicemail from earlier in the week! 😳🙈😂 Problem now sorted, many thanks for your response!… feel a right idiot now!🤷‍♂️🙈😂
Brian Chaloner
Message 3 of 33
Hi TaffStrat,
Can I just confirm is it slow blinking or rapid blinking? Slow blinking means that you've got a voicemail and rapid blinking means off the hook or user busy.
TaffStrat
Message 4 of 33
Hi Debbie, just an observation (although our telephone line appears to be fully functional), the telephone (blue) light on the Grandstream dva is still flashing intermittently despite having been reset twice! Should this be happening???
Brian Chaloner
Message 5 of 33
Hi @PaulE
I'm so happy to hear this, thanks for letting me know.
PaulE
Message 6 of 33
I have now reset the DVA with a pin as you suggested and it now seems to be ok. It accepts incoming calls and can make outgoing calls so that seems fixed.
Message 7 of 33
@PaulE
Apologies. Our Network Engineers have asked if you could try resetting the DVA again please, holding the pin in until the leds on top start blinking simultaneously. Please let me know if there is any change following this.
PaulE
Message 8 of 33
Mine is unchanged. Outgoing calls are engaged and it does not see incoming calls.
Message 9 of 33
Hi TaffStrat
I'm so glad to hear this 🙂
Thank you very much for letting us know 🙂
TaffStrat
Message 10 of 33
Hi Debbie, after resetting the Grandstream and all relevant equipment, I can confirm that our telephone line (both outgoing and incoming calls) is now back up and running! Many thanks!
Brian Chaloner
Message 11 of 33
Hi TaffStrat
Our engineers have identified the problem and are actively working to deploy the fix. We expect this to automatically update on your equipment in the early hours of the morning and your normal service to resume. We sincerely apologise and understand the inconvenience this has caused. Thank you for your patience whilst we have worked to resolve this issue.
Please can you retest?
Message 12 of 33
Our Service status page has now been updated
We are aware customers with FTTP services are currently experiencing issues making and receiving calls, our engineers are aware of the issue and are working hard to a resove this. We will provide any updates here, we apologise for any inconvenience this is causing.
Service Status | TalkTalk Help & Support
Message 13 of 33
Hi Paul
Apologies, I will post back as soon as we have further information.
PaulE
Message 14 of 33
Yes mine is almost exactly the same (I messaged Michelle a few moments ago). With mine all 3 lights on the Grandstream are on, not flashing, but any outgoing call is engaged and the it doesn't respond to any incoming call. I too have turned everything off for half an hour.
TaffStrat
Message 15 of 33
Many thanks Debbie!… I’ll await further response.
Brian Chaloner
Message 16 of 33
Hi TaffStrat
I'm really sorry about this.
Our Network/Incidents Team are looking at this now and I will post back as soon as I have further information.
TaffStrat
Message 17 of 33
Hi Michelle, apologies for delayed response… I’m just back from school runs etc! Have powered down all relevant equipment and the problem has unfortunately not been resolved!… the phone line is still “locked” in engaged mode, the blue phone icon on the Grandstream is still slowly flashing and we are still unable to make or receive calls!
As previously mentioned, we have elderly relatives with medical issues… so we rely on the phone for potential related calls.
Many Thanks!
Brian Chaloner
Message 18 of 33
Update on my last post -
We’re aware that some Full Fibre Digital Voice (VoIP) customers are currently unable to make and receive  calls.
Latest update: 08:10am 13th December 2023
Service has been restored, we recommend if you're still being affected, to power down both the eero router and the Grandstream digital voice adapter and use the factory reset pin, this will clear the issue.
Message 19 of 33
Hi TaffStrat,
I'm sorry for the delay. Have you tried powering down the ONT, router and DVA since the incident has been resolved just to see if this works? If not then we can pass this over to our Faults Escalation Team for further investigation.
TaffStrat
Message 20 of 33
Yes, I’ve experienced the very same this evening!… “Sorry we had a problem checking your services”. After checking “outages/issues” on the web, TalkTalk are claiming to have solved the problem… unfortunately not on my service though!
Brian Chaloner
