Turn off automatic channel optimisation
baldy1231
Message 7 of 7
Can you turn it off now please
6 REPLIES 6
Message 1 of 7
Hi @baldy1231
@Debbie-TalkTalk has asked me to help you. After my investigations are completed I do sometimes find that it is not WiFi optimisation that is causing the problems, but I am always impartial.
Message 2 of 7
Hi baldy1231
As my colleague Karl has confirmed, we are no longer able to switch off WIFI optimisation on the line.
Our Community Star @KeithFrench offers great advice on improving wireless performance. Could you help please Keith?
baldy1231
Message 3 of 7
Sagemcom it's the old router used before eero as the red port for faster fibre.
This is all in my account. Please check speaking to your colleague this morning on phone was cut off. Or you can call me back.
I'm a long standing customer at the moment feel I'm not being treated as such.
Message 4 of 7
We no longer have access to turn off Wi-Fi optimisation.
What devices are you using ?
baldy1231
Message 5 of 7
 Wi-Fi optimisation.
Can you stop putting the 2.4 on channel one?
My devices will not work on this channel.
If you can't do this I will see it as a breach of contract and will have no alternative but to terminate my contract.
As I'm not using eero router this can be done
Message 6 of 7
Sorry, we are unable to turn off Wi-Fi optimisation.
