Wi-Fi channels keep resetting and causing slow Wi-Fi
Robbievalentine
Message 5 of 5
So after I set my channels they change after a few hours which causes slow Wi-Fi and lagging in games etc getting fed up now as no one on talk talk live chat can seem to help me
4 REPLIES 4
Message 1 of 5
Hi @Robbievalentine
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 2 of 5
Thanks for your help @KeithFrench
Hi @Robbievalentine
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 3 of 5
Yes please that would be helpful
Message 4 of 5
Hi @Robbievalentine
The reason that they change is most likely down to WiFi optimisation trying to find a better channel. However, that does not mean that WiFi optimisation is to blame. It cannot be disabled any more as the support staff on here are not allowed to disable it. It is a business decision and nothing can be done about it.
However, I provide a free & impartial service to investigate the root cause of all WiFi reception issues & sometimes WiFi Optimisation is not to blame. Hopefully, my recommendations will resolve your issues.
The information below is provided by TalkTalk, for confirmation please contact @Debbie-TalkTalk or@Michelle-TalkTalk.
