WiFi Dropping some users
Wallclock
Message 3 of 3
  • My Black Talktalk Router occasionally drops some devices from the WiFi and not letting them reconnect. This has now happened a number of times recently and always around 8am. It doesn't effect all connected devices and those that lose connection are random, not always the same.
Resetting the Router cures the problem.
Message 1 of 3
Hi @Wallclock
Take Keith up on his offer to help, and we will follow his recommendation if equipment needs replacing.
Message 2 of 3
That sounds like classic WiFi interference. Which router do you have? From your description, this could be any one of about four or more routers. There is a sticker on the rear that will tell you.
Which WiFi band should these devices use that have this problem?
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
The information below is provided by TalkTalk. For confirmation, please contact @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
