on 19-06-2023 08:25 AM
Hi, I woke up this morning to find my WiFi not working. My router is just showing a solid Amber light. Trued resetting it but to no avail. I work from so this is something I need sorted ASAP.
I am based in Aberdeen, not sure if this is something affecting others or not
on 20-06-2023 09:05 AM
I'm glad to hear this and thank you for confirming 🙂
on 20-06-2023 09:04 AM
Morning, yes it came back around 4:55 pm yesterday. Just wanted to wait before confirming to make sure it was definitely working. Thanks for your help with this.
on 20-06-2023 06:40 AM
We've received an update to advise that this should now be resolved. Is your connection now working ok?
on 19-06-2023 03:03 PM
No problem 🙂
on 19-06-2023 03:01 PM
Thanks for the update, yes if you can carry on updating me please.
on 19-06-2023 02:22 PM
We've now received an update to advise that the engineer is investigating at the exchange. We'll continue to monitor this for you.
on 19-06-2023 12:15 PM
Apologies, I'll keep intermittently checking the fault and will let you know as soon as I know more. It's related to an outage that the engineer have been made aware of. I've also included our Compensation Policy below.
About your auto compensation credit - TalkTalk Help & Support
on 19-06-2023 12:04 PM
Well this is extremely disappointing. I'm assuming there will be some form of compensation for this? I'm having to use my mobile data so I can work but that's not unlimited, so I'm needing this back working today
on 19-06-2023 11:56 AM
I've just checked and it's still under investigation with the engineers who are working to resolve this. No estimated resolution date provided as yet.
on 19-06-2023 11:52 AM
Is there any update on this?
on 19-06-2023 09:45 AM
No problem 🙂
on 19-06-2023 09:41 AM
Great, thanks for your help
on 19-06-2023 09:39 AM
An issue has now been identified and this has been raised for investigation. I'll monitor this and will let you know as soon as I receive an additional update back.
on 19-06-2023 09:26 AM
Thank you
Have now found this and added it to the privacy notes as requested
on 19-06-2023 09:24 AM
Thanks for confirming. I'm currently looking into this and will post back as soon as I know more.
on 19-06-2023 09:14 AM
It was installed by cityfibre. I have tried resetting and powering down but it still doesn't work. And no, it doesn't work if connected directly to ont
on 19-06-2023 09:12 AM
Was this installed by Openreach or CityFibre? What lights are specifically on the ONT box? Have you also tried powering down the ONT for a full 30 minutes and retested? Does the connection work if you remove the router and connect wired directly at the ONT?
on 19-06-2023 09:01 AM
Any idea where I could find this number?
on 19-06-2023 08:55 AM
Hi Lewis
Thanks for confirming, do you have your FTTP order number so I locate the details please?
Can you add this number to the Private Notes section of your Community Profile.
