Wifi extender
Charlie_b
Message 15 of 15
Since installing full fibre, the router has been moved to a less central position in the house and the WiFi doesn't reach all the rooms.  Thinking of getting a booster.  How do I get the TalkTalk one? Not easy to work out how to do this on TalkTalk's website!
14 REPLIES 14
Message 1 of 15
Hi @BANAKYN
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
When you do create your own thread, please state the make/model of router that you currently have & why you think you need a WiFi extender.
BANAKYN
Message 2 of 15
Hello, can i get a wifi extender
Message 3 of 15
OK Charlotte, I've ordered them, they should be with you within a couple of working days
Message 4 of 15
Hi Chris,
Yes it would be great if we could give those a try please.  Many thanks,
Charlotte
Message 5 of 15
Hi Charlotte,
I'm really sorry but unfortunately I can't order the booster for you as it isn't specified for your package. I can send wifi extenders if you want to give them a try?
Message 6 of 15
Hi Debbie,
I didn't receive this Booster, but would still like to try one.  I'm pretty sure I added the information you needed on my Community Profile, but is there anything else I need to do?
Thanks,
Charlotte
Message 7 of 15
Hi Charlie_b
Please can you add your name and TalkTalk account number to your Community Profile, I can then send this out for you.
Message 8 of 15
Yes, that would be great.  Thank you.
Message 9 of 15
Hi Charlie_b
I can send you a WIFI booster for testing to see how the connection compares, would you like me to arrange this?
Message 10 of 15
Sorry, router not 'modem'
Message 11 of 15
Hi Michelle
It looks like the Fibre Connection box.  We were supplied with an Eero but the engineer could not use it because it needed more output sockets I think.  We are therefore using the same modem we had before.
Message 12 of 15
Hi Charlie,
Just to confirm, does it look like the below? The grandstream should be a digital voice adapter for VOIP.
Setting up your eero | Future Fibre | TalkTalk Help & Support
Charlie_b
Message 13 of 15
Hi Michelle,  Thanks - we're using a wifi hub. It says 'Grand Stream' on it.
Message 14 of 15
Hi Charlie,
Are you currently using a wifi hub or an eero please?
