on 13-01-2025 08:58 PM
Wifi light on router is not lit and I can't connect to the router on 192.168.1.1
Answered! Go to Solution.
on 15-01-2025 06:12 AM
What is your WPA Query ?
on 14-01-2025 01:58 PM
Thank you Karl, that won't be necessary, I have now managed to connect via cat5 cable and it is now sorted. I do have another query about WPA security, is it better to start a different thread for that?
Peter
on 14-01-2025 12:16 PM
Would you like to try another router ?
on 14-01-2025 11:43 AM
I can't connect to wifi as the wifi light on the router is not lit, so no wifi, when it is lit there is no problem connecting with a phone.
Peter
on 14-01-2025 10:44 AM
If you are trying to connect over wifi from a phone, always try a different browser, I find Opera browser is useful for testing.
on 14-01-2025 10:36 AM
I have a very old desktop that I will try, but the software is really old and I hope the browser will allow me to connect to the router.
Peter
on 14-01-2025 10:19 AM
Do you have any devices you can connect via ethernet to access the router ?
on 14-01-2025 10:07 AM
No, That didn't work, I have a feeling that I need to connect a computer to the router with a cat5 cable, but I no longer have a computer with a cat5 port.
on 14-01-2025 06:21 AM
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
Lat me know if this helps.
