eero 6 pro won't connect to TV via wifi.
aaronjunited
Message 27 of 27
So I have had the eero 6 pro for a few years now. I have an LG tv that won't connect to the router.
The connection is fine and everything is up to date on the eero. No issues except the TV not connecting.
Can anyone confirm if this is because of an old network adapter in the TV not being compatible with eero 6?
26 REPLIES 26
Message 21 of 27
Thanks. What happens when you try to connect the TV, do you get an error message?
Message 22 of 27
Yes everything was fine before the eero.
Message 23 of 27
Hi aaronjunited,
Just to confirm, has the TV connected OK with a previous router?
Message 24 of 27
OK, thanks for trying that. Let's see if the support team can help further.
Message 25 of 27
Thank you for your response. I tried this a few times. I hard reset the TV and restarted router. Still no connecting.
Message 26 of 27
Try temporarily disabling the 5GHz band in the eero and then try connecting the TV again.
https://support.eero.com/hc/en-us/articles/360049983772-How-Do-I-Temporarily-Hide-the-5GHz-Band-on-M...
