eero 6 pro won't connect to TV via wifi.
aaronjunited
Message 27 of 27
So I have had the eero 6 pro for a few years now. I have an LG tv that won't connect to the router.
The connection is fine and everything is up to date on the eero. No issues except the TV not connecting.
Can anyone confirm if this is because of an old network adapter in the TV not being compatible with eero 6?
26 REPLIES 26
DJI_MINI_2_SE
Whizz Kid
Message 1 of 27
I can get mine to connect using 802.11b but the speeds drop to 4.46 Mbps from 153.56 Mbps i am sat 6 feet from the router.
Message 2 of 27
Hi @aaronjunited
I have just forced the wireless adapter in my PC to use only 802.11b and it refused to connect to my eero 6. There is in my opinion no point in raising this as a bug with eero support, as it is so insecure.
Message 3 of 27
These are just WiFi diagnostic applications, which I did monitor my eero 6.
Message 4 of 27
Did you test the eero device itself with this software by any chance?
Message 5 of 27
Hi @aaronjunited
I need to change a statement I made previously. Both the eero 6 & eero Pro 6 DO support 802.11b, some diagnostic software I was using yesterday must have a bug in it. One application showed it did not support 802.11b and another one said it did.
So if you want to revisit this, I will try & help you. However, I still think that you would be much better off replacing that TV.
DJI_MINI_2_SE
Whizz Kid
Message 6 of 27
"Personally, though, I would just buy a new TV."
I recently bought the TV below for the bedroom as we do not have an aerial socket in that room, TV progs play with no buffering  on wi-fi and Netflix HD  also works  with no problem at all, at £119 its a steal.
Buy Bush 24 Inch 24HT24CA Smart HD HDR10 LED TiVo Freeview TV | Televisions | Argos
Message 7 of 27
You could buy a cheap network switch such as this:-
https://www.amazon.co.uk/TP-Link-LS1005G-Wallmount-Ethernet-Splitter/dp/B07VWB347G/ref=sr_1_4?crid=Y...
Remove your PC from the eero & connect the switch to it, then connect the PC back up to a spare port on the switch.
Then buy yourself a pair of powerline adapters, providing an ethernet connection over your mains electricity. One unit would connect to another port on the switch & the other to the TV's Ethernet port. However, both units must be on the same electrical ring circuit for this to work properly & should be connected directly to wall sockets, not extension leads etc:-
https://www.amazon.co.uk/NETGEAR-PL1000-100UKS-Powerline-Ethernet-Homeplug/dp/B01BD9TFI4/ref=sr_1_16...
Message 8 of 27
Ahh damn. I see. So as i suspected i knew the eero was causing me difficulties.
Connecting via ethernet isn't an option for two reasons. One being there is only one ethernet connection on the eero that goes to my PC in living room.
Two: I have no way of getting a cable up to the bedroom.
Message 9 of 27
HI @aaronjunited
EDIT: Both the eero 6 & pro 6 support 802.11b, g,n & ax, not 802.11b. However, 802.11b is so insecure it should never be used.
Message 10 of 27
Hi @aaronjunited
@Michelle-TalkTalk has asked me to help you. If your TV only uses 802.11b, then it is very insecure and should not be used. However, I will have to look into the specs of your eero Pro 6 to see if it even supports that standard. Could you connect the TV via an Ethernet cable?
Message 11 of 27
@KeithFrench - Would you be able to provide any advice please?
Message 12 of 27
The older talk-talk router was on the 2.4GHz band and the eero has a function that disables the 5GHz band to allow 2.4GHz to connect without interference. But sadly this doesn't work.
DJI_MINI_2_SE
Whizz Kid
Message 13 of 27
I found the wi-fi specks for your monitor if these are correct cold this be the reason you are having problems -
802.11b is one of the oldest Wi-Fi standards. It supports a theoretical maximum throughput of 11 Mbps over short ranges using the 2.4GHz band.
Message 14 of 27
I used a second eero 6 borrowed from a friend to extend Wi-Fi upstairs. But that made no difference to the situation.
Message 15 of 27
I don't know how feasible it is but have you tried moving the TV nearer to the eero to see if it's a wifi range issue?
Message 16 of 27
Always wifi with previous router as it's in the bedroom and no ethernet going up there from down stairs.
Wifi signal was full bars with previous router.
Message 17 of 27
Thanks, and you definitely connected it by wifi to your previous router and not Ethernet cable?
Message 18 of 27
It's an LG model: 29MT31S-PZQ
Message 19 of 27
What's the model number of your TV?
Message 20 of 27
No wifi shows up to connect to. I have disabled the 5ghz band temporary to see if that helped. I have reset TV many times.
