on 17-09-2024 01:59 PM
A connection test is still open because no fault has been detected. Therefore I cannot run another test, whilst it is open. Further, I cannot run a speed test because it runs into problems and does not finish. Pressing the blue contact the team button, does nothing. Ditto the contact link in an email.
My connection appears to be flaky, as some web pages load in short stages, but ut seems that I am not going to get any help from tech.
on 18-09-2024 11:41 AM
Glad this seems to have abated. We do advise to power off the ONT for 30 minutes as this will reset the session incase a stale session exists.
It may be a simple solution in some cases, but I think the Switch Off / Switch on will always be around where technology is involved as it does fix a lot of issues. Whether it's a printer, a phone, or some other internet technology 🙂
on 18-09-2024 11:35 AM
Thank you.
Somewhere in all of this, the problem has vanished, though I do despair somewhat, that after over 40 years, "switch off and switch on again" is still a standard repair tool.
Grandude
on 17-09-2024 03:11 PM
Line tests are currently clear and no issues detected remotely.
You can also check your speeds at : https://www.supportal-test.co.uk/
Can you power off the router and the ONT for 30 minutes. This will create a new session.
If the connection is dropping, check the lights on the ONT remain green and no LOS light is illuminated.
Also, if you are using a device connected via Wi-Fi , can you check with a wired device to rule out a local Wi-Fi issue etc.
on 17-09-2024 03:09 PM
