Home Phone
Caller Display not working
AdrianGrid
Message 46 of 46
Good morning,
Caller Display stopped working about 2 weeks ago, the display shows "External Call".
All 3 handsets show the same message.
Caller Display is shown as active in my account settings.
I have tried the following:
1. Remove the Caller Display option and confirm it's removed, then add it back on.
2. Power down the base unit for a few minutes.
3. Reset the base units and handsets.
None of this has worked, so I assume it must be a fault your end.
Adrian
There are two rules for success:
1. Don't tell everybody everything
2.
45 REPLIES 45
Message 41 of 46
Hi @AdrianGrid
Thank you. I'm just looking into this and making some changes to try and resolve this issue.
I will post back here as soon as I have further information.
Message 42 of 46
Hi Debbie
Account number added.
2.
Message 43 of 46
Hi AdrianGrid
Can you add your TalkTalk account number to your Community Profile (in the Private Notes section) I can then look into this further.
Message 44 of 46
Hi Debbie
The master socket doesn't have a test socket that I can see, other than if I unclip the front it reveals the socket that the front cover connects to. I have plugged the phone into this but it has made no difference.
2.
Message 45 of 46
Hi Adrian
Can I just check, have you tested the caller display handset directly at the test socket?
