Home Phone
False "Missed Call" every 30 minutes since Full Fibre installed
Nigel_H
Message 14 of 14
Since our move to Full Fibre in January, our home phone registers a Missed Call every 30 minutes, at 3 minutes past every hour and half hour. The phone does not ring (luckily) and no-one is calling us, but we have to delete all these 48 non-calls from the phone's call list every day, or the memory fills up.
Our home phone is a BT Premium Model 090631, connected to a TalkTalk Sagemcom-FAST5464 router. We have tried all the suggested tests without any success, but the Home Phone test result is a message telling us that the line cannot be tested since we still have a copper connection as well as fibre. We don't, although there's still a copper line stretched across the road to our house.
Please Help!
Nigel H
13 REPLIES 13
Message 1 of 14
I've just posted on your topic now.
Message 2 of 14
Thank you
Message 3 of 14
Thank you and we'll pick up your topic shortly.
Message 4 of 14
@Jimbob69
I see you have started your own topic, the support team will reply there as soon as they can.
Jimbob69
Message 5 of 14
Hi, Having exactly the same problem Phantom missed calls every half hour 23 & 53 past evry hour. How was this resolved?
Thank you
Message 6 of 14
You're Welcome 🙂
Message 7 of 14
Yup! Looks like the problem's solved.
Many Thanks for your help.
Nigel
Nigel H
Message 8 of 14
Hi Nigel
This should be done now.
Message 9 of 14
No Problem 🙂
Message 10 of 14
Thanks Karl. That's good to know.
Nigel H
Message 11 of 14
Hi Nigel
I've escalated this to our network teams to have the fix applied for you.
Message 12 of 14
Thanks Gliwmaeden2, that's a relief. . .
Nigel H
Gliwmaeden2
Message 13 of 14
It's a "known issue", @Nigel_H.
Staff will sort it out after the weekend.
