on 29-09-2025 04:29 PM
Over the weekend, I have lost the ability to receive or make calls on my landline. Internet appears to be unaffected, so I have done the usual tests - check on the test socket with a wired handset.
Fault was checked on the website, and they confirm that there is a fault, and that I need to speak with a Team member. The blue button does not link to anything though, with no chat window coming up or details of a phone number to contact.
Please can someone help to resolve this?
on 17-10-2025 09:03 AM
Please can you confirm that the base station is powered on?
on 17-10-2025 09:02 AM
Cordless, but have a corded one available
on 17-10-2025 08:58 AM
Which type of telephone do you currently have connected?
Corded
Cordless
on 17-10-2025 08:40 AM
Hi, currently at home
on 17-10-2025 08:27 AM
Hi @jlyons1978 I will be able to continue with the checks, please confirm if you are at home.
on 16-10-2025 06:08 PM
tested, no change. Also checked with old style phone in test/master socket
on 16-10-2025 05:59 PM
We are still running checks on our end, please try to use your telephone and confirm if the phone service is working okay.
on 16-10-2025 05:50 PM
just checking if there is any update on this before Support shuts down for the night?
on 16-10-2025 05:07 PM
Thank you, a line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 6 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
on 16-10-2025 05:06 PM
yes, currently unable to make outgoing calls. If I try to ring my landline off my mobile, I get a voicemail message ('person you have tried to call is on the phone'). Internet is fine, but unable to use phone
on 16-10-2025 05:02 PM
Is the issue happening right now?
silence
on 16-10-2025 04:59 PM
Please describe what you can hear when you try to use the phone?
Silence
Noise on the line
Intermittent Dial Tone
Consistent Engaged Tone
on 16-10-2025 04:37 PM
I'm home now, and will be working from home tomorrow
on 16-10-2025 12:17 PM
Thank you for confirming. Please let us know when you’re prepared to begin diagnostics tomorrow. Thanks
on 16-10-2025 10:49 AM
Hi, I will work from home tomorrow
on 16-10-2025 08:23 AM
Hi there @jlyons1978, we do need to be at home so we can proceed as we need to you to monitor the landline, make test calls and so on, thanks.
on 15-10-2025 06:34 PM
I'll see if I get a response tomorrow, but otherwise I will try to arrange to be home Friday.
on 15-10-2025 06:31 PM
They seem to need you to be there to actively run them and tell you what to do next, @jlyons1978.
on 15-10-2025 06:30 PM
If they can do the line checks without me at home, it would be beneficial. Otherwise I'll need to ensure I work from home that day, but I would need my internet connection.
