Home Phone
Landline - no dialtone + incoming calls going straight to voicemail
jlyons1978
Chat Champion
Message 95 of 95
Over the weekend, I have lost the ability to receive or make calls on my landline. Internet appears to be unaffected, so I have done the usual tests - check on the test socket with a wired handset.
Fault was checked on the website, and they confirm that there is a fault, and that I need to speak with a Team member. The blue button does not link to anything though, with no chat window coming up or details of a phone number to contact.
Please can someone help to resolve this?
94 REPLIES 94
Message 41 of 95
Please can you confirm that the base station is powered on?
Message 42 of 95
Cordless, but have a corded one available
Message 43 of 95
Which type of telephone do you currently have connected?
Corded
Cordless
Message 44 of 95
Hi, currently at home
Message 45 of 95
Hi @jlyons1978 I will be able to continue with the checks, please confirm if you are at home.
Message 46 of 95
tested, no change. Also checked with old style phone in test/master socket
Message 47 of 95
We are still running checks on our end, please try to use your telephone and confirm if the phone service is working okay.
Message 48 of 95
just checking if there is any update on this before Support shuts down for the night?
Message 49 of 95
Thank you, a line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 6 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
Message 50 of 95
yes, currently unable to make outgoing calls. If I try to ring my landline off my mobile, I get a voicemail message ('person you have tried to call is on the phone'). Internet is fine, but unable to use phone
Message 51 of 95
Is the issue happening right now?
Message 52 of 95
silence
Message 53 of 95
Please describe what you can hear when you try to use the phone?
Silence
Noise on the line
Intermittent Dial Tone
 Consistent Engaged Tone
Message 54 of 95
I'm home now, and will be working from home tomorrow
Message 55 of 95
Thank you for confirming. Please let us know when you’re prepared to begin diagnostics tomorrow. Thanks
Message 56 of 95
Hi, I will work from home tomorrow
Message 57 of 95
Hi there @jlyons1978, we do need to be at home so we can proceed as we need to you to monitor the landline, make test calls and so on, thanks.
Message 58 of 95
I'll see if I get a response tomorrow, but otherwise I will try to arrange to be home Friday.
Message 59 of 95
They seem to need you to be there to actively run them and tell you what to do next, @jlyons1978.
Message 60 of 95
If they can do the line checks without me at home, it would be beneficial. Otherwise I'll need to ensure I work from home that day, but I would need my internet connection.
