24-02-2024 01:54 PM - edited 24-02-2024 02:07 PM
Good afternoon,
I have been experiencing a problem with my landline for the last few months whereby callers using BT/EE or O2 providers have been unable to make incoming calls to my number. They all report hearing either the engaged tone or the “the number you have dialled has not been recognised” message.
I reported this issue at the end of last year at the same time as another fault where the telephone was only ringing twice, then cutting out at my end but still ringing for the caller but without the ability to connect if I answered. Two BT Openreach engineers visited the property and were able to establish the following:
I understand that a system resync was subsequently performed at your end, however since then the problem with BT/EE/O2 users not being able to connect has gone from being an intermittent fault to a permanent one. This is totally unacceptable and it is pointless to have a landline that does not accept calls from certain providers. My wife and I both have elderly parents with whom it is important we keep in contact, as well as hospital appointments and other such arrangements it is imperative we manage by phone. I can confirm that I have never activated call barring/blocking either on my TalkTalk account (see attached screenshots) or on the phone itself and have no other equipment at the property that could be causing this problem. It is clearly a fault at your end and I must ask that you look into it as a matter of urgency; if it persists I will have no alternative but to switch providers.
TalkTalk account Boosts settings
Callsafe is OFF
on 29-02-2024 12:36 PM
OK, I've passed on your comments to our Network team, I'll let you know when I receive an update
on 29-02-2024 11:00 AM
Hi Chris,
No I haven't heard from the network team since I spoke to them on Tuesday; only an automated text from Openreach after the engineer left this morning to say they're "still working on repairing your service".
on 29-02-2024 10:31 AM
Thanks for the update. Have our network team arranged to call you back?
on 29-02-2024 09:35 AM
Hello Michelle,
The BT Openreach engineer Alex has just left after checking the line to the property. He was able to replicate the fault and has said that, having tested everything and been to the exchange, it is an issue with TalkTalk's software not allowing numbers from certain providers to get through. He has logged this with you and requested action at your end as there is nothing else he can do on his part.
on 28-02-2024 08:14 AM
I believe that our faults team have been in contact. Please let us know how you get on.
on 27-02-2024 10:07 AM
OK thanks. I'll pass this over to our network team and ask them to take a look
on 27-02-2024 09:49 AM
Hi Chris,
Yes, that's correct. My wife and I (& others) are with Vodaphone and have no trouble, but BT/EE (landline & mobile) and O2 users report the aforementioned problems.
on 27-02-2024 07:44 AM
OK thanks. As far as you are aware is it all BT/EE and 02 callers?
on 26-02-2024 05:53 PM
Hi Chris,
Thanks for looking into this. Unfortunately I can confirm that the problem is not fixed - BT/EE and O2 callers are still receiving the engaged tone or "this number has not been recognised" message.
Nick.
on 26-02-2024 08:41 AM
Hi NJR83,
I've made a change, could you please retest and let us know if it has resolved the problem
