For any questions about your TalkTalk mobile service.
Friday
I want to extend the Ring Time on my mobile ( Samsung A23 ) which I believe requires the appropriate MMI code for the network rather than being phone specific as an earlier similar query was answered.
The phone is a Dual Sim and I have changed the Timer for the other SIM using their MMI code.
thanks
Phil
Friday
Thanks Arne - that did the trick. Phil
Friday
Hi Samsung community says
1) Type **61*321**00# on your keypad. Replace 00 in the code with the number of seconds you want your phone to ring. Tap the Make Call button.
Hope that helps
