Online security
Get answers and information about our security products.
scam protection off not working
kingsizefairy
Message 7 of 7
I have turned off the scam protection as well as the kid's filter.
Both are turned off, I still cannot access several pages.
I tried on different browsers, have cleared the cache several times but  no, I am unable to access e.g. the page of my local newspaper
Same goes for pages, which are apparently not for kids or deemed unsafe for whatever reason. I am far away from being a kid ...
Can this be fixed, please?
6 REPLIES 6
Message 1 of 7
Excellent, thanks for posting back to let us know it's sorted.
Ady
Message 2 of 7
I managed to change the settings on the allow list and after that everything was working fine. So Problem solved.
Message 3 of 7
When you turned the router off did your IP address change if not turn it off for longer and if you can overnight. 30 mins should do, but sometimes longer is required.
Ady
Message 4 of 7
OK, found it. we will see how this will work or not. Thanks for your answer
Message 5 of 7
I have switched the router off, yes, but that did not change a thing.
Where can I find the allow pages?
Ady-TalkTalk
Message 6 of 7
Hi kingsizefairy, have you tried turning off the router for at least 30 minutes although preferably for an hour? If not give that a go and that should clear the page blocking. Have you also tried adding the newspaper's URL to the allow pages?
Ady
