on 09-12-2023 02:12 PM
I received my new 4K box a couple of weeks ago but unfortunately I am unable to play 'on demand' programmes on channel 5. When I select a programme a small dial appears on a grey screen, which it does for all channels on playback, it rotates a few times then instead of opening the programme, the screen goes black and freezes. The only button on the remote that works at this stage is the on/off button, so switching off each time is my only option.
Is there a solution or is the box faulty? Thanks in anticipation,
Poppy.
on 14-12-2023 07:49 AM
The sound issue is not normal, you might want to try a box reset - press the button on the side 5 times to initiate a reset, then set the box back up and see if the sound issue keeps happening.
on 13-12-2023 05:06 PM
Thanks for your reply about Channel 5 problems - I hope this will soon be resolved.
I also should have mentioned the other annoying problem I have with the box - when I first switch it on the screen appears but without sound. To get any sound I have to switch the box off, then when I switch back on the sound is on. Is this normal??
Thanks again,
Poppy
on 11-12-2023 07:52 AM
The My 5 app has been problematic across the youview platform. This is an issue with the App itself and My 5 are aware.
