4k talktalk box keeps buffering on BBC Iplayer
Nicolajmorris
Message 3 of 3
Every time we watch BBC Iplayer it buffers constantly on the programme
Message 1 of 3
HI @Nicolajmorris
Did the above advice help?
Message 2 of 3
Try rebooting your router first.
If that doesn't work then as this is only happening on the one app, the only other thing to try is factory resetting your box to reset the iPlayer.
If you have recordings though, you will lose these.
