on 11-05-2024 08:50 PM
My programmes stutter intermittently and an HDR prompt comes up in the right top screen. How can I stop this
on 13-05-2024 08:11 AM
Hi @SarahT1
Did the advice from my colleague help?
on 11-05-2024 09:24 PM
The HDR logo comes up when a 4k TV or 4k programme is being streamed. This is normal.
As for stuttering, this could be due to a variety of issues
Are you using the HDMI cable supplied with the box? Older cables are not capable of sending 4k content to the TV.
Try rebooting your router
If these don't help, then try factory resetting the box to ensure there are no bugs in the software and / or the apps.
If this goes not help then please post back for support staff to look into further next week
Thank you.
