D-Link has stopped working
Lemon2
Message 3 of 3
my D Link DHP300 AV has stopped working meaning no access to manyTV Channels
Message 1 of 3
Try the reset option mentioned by fr8ys and see if this helps.
You may have an older TV Box if you are unable to connect via Wi-Fi
Message 2 of 3
Which box do you have as only the 4k box has additional channels delivered via the internet, or do you mean catch-up TV.
Normal channels should not be affected.
Have you tried resetting the power plugs? There should be an accessible pin hole reset that you use when plugged in.
Let us know how you get on and staff will pick this up next week when they are back.
