Error code 02110
ufo_SE266DP_1
Message 3 of 3
We are experiencing this regularly and BBC iPlayer keeps buffering! I have used WiFi, cable and restarted the box and router it still keeps happening
Message 1 of 3
This sounds like an iPlayer issue rather than a TalkTalk one, but so we can offer advice what device are you using to view the iPlayer?
Message 2 of 3
OK, this could be app related.  Press the button on the side of the box 5 times to initiate a reset, this will then re-install all apps.
See if this helps.
