IPlayer
Fred147fred
Message 4 of 4
My tv goes to iPlayer when I select bbc1/2 then  i’am unable to get subtitles
3 REPLIES 3
Message 1 of 4
Netgem are rolling out a configuration change this week to resolve this issue.
Message 2 of 4
Hi @Fred147fred
This can happen if reception is poor.  Connect the aerial direct to the TV and check to see if the picture is breaking up or if you have a strong signal.
Message 3 of 4
It's a known issue. Use 101 and 102 which work normally, and the picture quality is better.
Anonymous User
