Netflix
Scotia55
Whizz Kid
Message 21 of 21
Recently took out a subscription to Netflix which works fine on my phone, laptop and firestick.  However, cant get it on the TV.  Message says your plan does not support streaming on this device though when i took out the subscription I did tick the box for TV.  I took out the subscription via the Netflix website rather than through Talk Talk.  Is that the reason I cant get it on the TV?
20 REPLIES 20
Message 1 of 21
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
Juju01
Message 2 of 21
Hi I paid yesterday for Netflix as a warning saying I need to put my bank details in to continue and be charged £17.99 yet I went to netflicks and purchased the package it’s fine on my phone but not on my tv ?
Message 3 of 21
Find the post you think helped the most. At the bottom of the post right hand side in line with likes, are 3 dots click on these and a menu appears.
Message 4 of 21
Installed TV Hub box this morning and pleased to say everything works as it should including Netflix and Prime.  Thanks for the help.  How do I mark this as solved?
Message 5 of 21
They have sent me a new TV hub box. Spent nearly 2 hours on text with them yesterday.   It was a marathon and I was swiftly losing the will to live by the end.  Anyway box arrived today.  Quick service. Will install it tomorrow.  My contract was renewed just a couple of months ago.
Message 6 of 21
Just to clarify, its the older YouView boxes that with adverts does not work.
It does work on the 4k and TV Hub boxes, but you will probably have to recontract if you want one of those.
Message 7 of 21
Netflix works on my firestick.
Message 8 of 21
Talktalk is I believe promoting the basic Netflix package with ads so it must work.  They have sent me a new TV hub box but haven't installed yet.  I'll do that tomorrow and let you know how I go.  No intention of changing my Netflix plan as the others are just too expensive.
Hopefully with the new box it will work.  🤞
Message 9 of 21
TalkTalk, or rather YouView are only the facilitator of the app on the box. The app is owned by Netflix. They changed the basis of their basic package to include adverts. The box hardware will not run the software required.
If you took Netflix via TalkTalk, I believe they do not sell the basic package with adverts.
If you still have an issue @Pedro406 please start your own thread.
Message 10 of 21
I have just joined Netflix with the basic package like you it will not let me stream anything message from Netflix need to upgrade that i don't need just now. They are happy to take our money but don't mention that it only works with certain boxes even though i ticked all the correct boxes for use, i have older box that records ( very handy ) if i went through TalkTalk for Netflix would i have the same problem needing to upgrade . I have a smart tv ( pretty old now ) it just seems loads of hassle i have a firestick ( no Amazon account ) should  i use that system if that is not successful will cancel with Netflix. Looks like TalkTalk are the problem with this.
Message 11 of 21
The new boxes are like your fire stick but in a box which has a tuner in. It much like what you have but with apps that are up to date and work.
Check out the Hub and 4k boxes using the link below so you can make an informed decision.
https://community.talktalk.co.uk/t5/Articles/Compare-our-TalkTalk-TV-Boxes/ta-p/2204428
Message 12 of 21
Thanks for that.  No the box I have doesn't record and you're right, ITVx doesn't work either. Not quite sure what the benefit would even be to upgrade box given it would probably cost me. What exactly would be the said benefit?
Message 13 of 21
Should mention that TalkTalk no longer provide boxes that record, so if yours does it may be worth sticking with it and use your firestick.
ITVX also won't work on older boxes but will on your firestick.
But if you do want the latest box offering follow Karl's advice.
Message 14 of 21
If you have a smart TV with it's own set of apps, then netflix should work from that, but to upgrade to a later box, give our teams a call and they can discuss options and offers with you - 0345 172 0088 , you may be asked to renew the contract if out of contract currently.
Message 15 of 21
Thanks for that Karl. How do I upgrade the box given it is so old?  As I say, I can access it fine via my Firestick but make life a bit easier it I don't have to change input every time I want to watch it.  And definitely don't want to upgrade Netflix package.
I assume my TV is a smart one, given it's only about 3 years old.
Message 16 of 21
The older boxes will not currently support Netflix With Ads, so you may need to upgrade to the latest box or if you have a smart TV, try to access from this.
Message 17 of 21
Hi Karl
Just the netflix app which comes pre loaded.  Like this.
Message 18 of 21
It is the package with ads. But I've no notion of updating to a more expensive one.  It works fine on my firestick.   Don't know what box I have but I've had it for about 10 years so pretty old.
Message 19 of 21
When you say you cannot get netflix on the TV, is this directly on your own smart TV or via a TalkTalk TV Box.
Message 20 of 21
Which box do you have? Which Netflix plan do you have?
Not all versions of the Netflix app support the with adverts package foe example.
