PIN Number requests using TV HUB
Message 4 of 4
If you have successfully signed into Apps such as ITVX and you are asked for a PIN number, this may be due to Parental Controls being set up during set up.
The Box default PIN is 1234. Try this to access and unless you require Parental Controls to be on, turn this off in settings. It's under TV Settings.
3 REPLIES 3
BeatriceG
Message 1 of 4
Perfect. Thank you, fr8ys!
Message 2 of 4
Glad you got the answer you were looking for 🙂
hally001
Message 3 of 4
Thanks - worked for me 🙂
