Recordings failing
DaisyB65
Message 6 of 6
All of a sudden everything I try and record is failing. any ideas why?
5 REPLIES 5
Message 1 of 6
A full factory reset will erase and set up the hard drive, but that is the only option if the maintenance reset has failed.
Message 2 of 6
Thanks. I tried the first thing and it didn't work. I'm guessing if I do the second thing, I'll lose everything I have saved already recorded? I'll try later in the week. Thanks for your help.
Message 3 of 6
Try a Youview Maintenance Reset  and see if this helps.
If recordings still fail after this then the only option is a full factory reset from the settings menu.
DaisyB65
Message 4 of 6
TalkTalkYouView Huawei
Message 5 of 6
What model of TV Box do you have ?
