TV Box
on 13-12-2024 05:10 PM
Message 3 of 3
My TV Box is a Huawei No DN372T. At present I am having trouble recording programmes (says will record bur when I check afterwards find is has failed to record) and also find I am unable to watch programmes that I have successfully recorded earlier). I have tried rebooting the box a number of time to no change. I know that there is a system to check if the latest software in being used but a PIN is required which I do not have (If I did have one I have either lost it or forgotten it). Do I require a new TV Box (and if so how do I go about getting one) or is there a fix that I have no tried. Many thanks
Clive12 (novice)
Labels:
- Labels:
Settop box
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 16-12-2024 09:16 AM
Message 1 of 3
Hi Clive12
Did the advice from fr8ys help ?
Did you try the reset options ?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-12-2024 06:33 PM
Message 2 of 3
Unfortunately these boxes are reaching end of life now but you may be able to rescue the box.
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
If you wish one of these streaming boxes, Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Hope it works and please let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
