on 09-01-2025 02:19 PM
Can anyone assist. Despite not changing my wifi or tv box set up recently over the last month my talktalk TV 4K box keeps dropping the connection with the wifi hub router. The only way I can reset it is to reboot both the wifi router and the tv box and then it finds the connection. Has anyone got any suggestions.
on 21-01-2025 08:35 AM
A replacement box has been ordered for you.
on 21-01-2025 08:25 AM
yes please
on 21-01-2025 07:58 AM
OK, would you like to swap out the box and try another ?
on 21-01-2025 07:56 AM
No just the tv box
on 21-01-2025 07:53 AM
Do any of your other Wi-Fi devices drop the connection ?
on 20-01-2025 09:04 PM
I have tried this and still no better?
on 09-01-2025 02:50 PM
There is no way to reset the box without losing recordings.
Also, Netgem are rolling out a config update to reduce the Iplayer issue. This is usually triggered if the signal for the channel is weak.
on 09-01-2025 02:45 PM
on 09-01-2025 02:38 PM
It will remove any recordings on the usb drive as that will need to reinitialise.
on 09-01-2025 02:28 PM
If I do this will I lose all my recorded programmes on the hard drive?
on 09-01-2025 02:23 PM
Try a reset of the box as detailed here :
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
See if the box then continues to drop the Wi-Fi
