loss of HD channels
delton1
Message 5 of 5
During last two months keep losing HD channels & have to watch on ch 800+ was advised to get a new aerial  this done still same problem suspect Netgem box is this correct.
4 REPLIES 4
Anonymous User
Message 1 of 5
Thanks for confirming.
Message 2 of 5
Hi @delton1
If you connect the aerial direct to your TV, do you notice any reception issues with these channels, any picture breakup etc ?
Message 3 of 5
Thanks for info will have to wait for netgem/talktalk to update box.
Message 4 of 5
I have been offering suggestions regarding issues with the Netgem box, but reported issues seem to be increasing, so don't want to waste your time with potential solutions that may not work.
I know these issues have been reported to Netgem and TalkTalk are awaiting a firmware update to apply to the boxes.
Staff are back on Monday and will hopefully be able to advise further then.
In the meantime I suggest you put the aerial in the TV and bypass the box and use your TV tuner if possible.
Anonymous User
