on 06-02-2023 10:46 PM
We’ve just upgraded to full fibre and could not connect the Youview tv box to the new WiFi router. Contacted TT who said we would need a 4K TV box which was sent. This connected without too much trouble but has no record function. Is one available that is compatible with full fibre?
Also one other question. Previously I had an Ethernet cable connected from the old box to a power line adapter. Do I still need this? It seems to work ok without. Thanks for any advice.
on 07-02-2023 04:03 PM
The boxes do not have these built on.
Only thing I can think of, is that either it was removed at install or some one in the home may have relocated it etc, but they do only work in pairs.
on 07-02-2023 03:19 PM
I see what you’re saying but can’t understand why understand why it worked with just one connected to the box prior to changing to FF. Also the help screen says if the distance from the router to box is greater than 2 meters to be connected with an Ethernet cable use a PL adapter (singular) and shows a picture of ONE connected to the router. Do any of the tv boxes have a receiver in them?
on 07-02-2023 02:39 PM
OK, This is definitely a powerline adapter, not an extender. These devices work in pairs or more, so you can have 2, 3 or more, but never just one on its own, there needs to be at least 2 to work.
The first would connect to a socket near the router, with an ethernet lead to the router, and the second device would be at another location within the home.
The first adapter converts the signal from the router to allow it to be sent through the electrical wires in the home, and the receiving unit will convert the signal back so it can be passed over ethernet to your device.
So there must be 2 of these devices to make it work, one as a transmitter and one as a receiver.
on 07-02-2023 02:30 PM
It’s the second one.
on 07-02-2023 01:53 PM
Does the adapter look like the first model or the second one on this page
Wireless Powerline adapter guide - TalkTalk Help & Support
on 07-02-2023 01:21 PM
The help me connect advice is connect one PL adapter to the router though.
on 07-02-2023 01:19 PM
Thanks. No I’ve only been using one connected to the box not another one connected to the router. That worked fine prior to FF and a new router.
on 07-02-2023 01:09 PM
The little black Dlink powerline adapters work in pairs, not over wifi, and should be used as in the picture in my last post.
on 07-02-2023 01:00 PM
I may have he terminology wrong. There is only one connected to power and to the box via an Ethernet cable. It has DLink on the back if that helps.
on 07-02-2023 12:52 PM
The PLS Setup is usually like this :
on 07-02-2023 12:50 PM
You should have 2 powerline adapters, one at the router end and another near the TV, or are you talking about a wifi extender ?
on 07-02-2023 12:47 PM
The HDMI lead isn’t long enough to still reach to the tv if the box is moved to the router.
I’m only using one PL adapter btw.
on 07-02-2023 12:30 PM
Try putting the Powerline Adapters's in a double wall socket side by side and pair them together. See if the lights come on.
As for the TV box, take this to the router, forget the Powerline Adapters's for this part, just connect the TV Box direct to router for setup.
on 07-02-2023 12:26 PM
Hi Karl no luck I’m afraid. Still no WiFi connection. No middle WiFi light lit on the PL adapter. The on screen help just saying connect an Ethernet cable (too far) or PL adapter (already connected and plugged into the back of the router.) Everything switched on and off. PL pairing switch held down. Anymore thoughts?
on 07-02-2023 11:28 AM
No Problem 🙂
on 07-02-2023 11:27 AM
Thanks Karl that’s clear. Will give that a go.
on 07-02-2023 11:13 AM
Forget anything wifi, as it's not applicable here. If the box is not connecting, move the TV Box over to the router and connect it directly to the router with an ethernet cable to complete it's setup, then you can move it back.
on 07-02-2023 11:06 AM
Thanks for your suggestions Karl. So just so I’m absolutely clear I should unplug the Ethernet cable from the PL adapter to the tv box and move it from its present tv location temporarily directly to plug into the router on the other side of the room and plug into the wall socket. Then I can move it back to its original tv location and reconnect to the tv box? Do I need to go through the whole set up procedure as if it was an initial installation or just go through Settings and WIFI? Sorry for the endless questions but I’m eager to sort this if it’s possible.
on 07-02-2023 10:35 AM
OK, we did supply 3 models of older youview box, DN360T, DN370T and DN372T.
All these models connect via ethernet and do not require any config or passwords entering etc.
They usually connect to the router directly, but if using powerline adapters, make sure the adapters are connected, one to the router via ethernet, and both adapters are plugged directly into wall sockets.
Some times the box can have an issue obtaining updates when first set up via powerline adapters so it is best to connect directly to the router just while setup completes.
on 07-02-2023 10:30 AM
It’s an older Youview TalkTalk Hueawi box connecting to a Sagemcom router. I think it was superseded by Plus?
