TalkTalk TV Hub - changing channels delay?
GMcDon
Message 3 of 3
My  brand new TalkTalk TV Hub is taking about 6 seconds to change channels?
Why is this the case?
Message 1 of 3
Hi @GMcDon
Did the reset help ?
Message 2 of 3
This does seem a long time so I'd suggest you try resetting your box to clear any bug if present.
Instructions can be found here.
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
