TalkTalk box replacement remote
NICKT2
Message 7 of 7
Can anyone help my find a replacement remote like the one in the image? Any help much appreciated.
Nicholas Taylor
6 REPLIES 6
Message 1 of 7
Hi Nick
I've sent you a PM with some more info.
NICKT2
Message 2 of 7
Hi Karl
I've updated my profile as requested. Thanks for looking into this for me. Nick T
Nicholas Taylor
Message 3 of 7
Hi @NICKT2
Can you please update your Community Profile to include your
  • Name
  • TalkTalk Telephone number or Account number
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Message 4 of 7
@DamoD
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
DamoD
Message 5 of 7
Ooh I'm here for the same reason. I have been with TV for over a week as the 4k remote has disappeared! So we aren't able to buy or order a replacement? Anything online looks similar but had Prime instead of Netflix button
Message 6 of 7
I don't think TalkTalk have replacement remotes for the 4k box.
If you explain what the issue with it is, support staff may be able to help.
