Tv 4k box
Frontline
Message 3 of 3
4 k tv box goes straight into bbc iplayer and  all itv programmes lost, message says invalid channel number
Message 1 of 3
BBC Iplayer will launch when there is a poor signal, and if the ITV channels are failing, there could be a poor signal due to the bad weather.
Connect your aerial direct to your TV and see if the signal is poor for those channels.
Divsec
Message 2 of 3
Hi @Frontline sadly you are not alone in this. Your post has been escalated and you should hear soon
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
