Tv connection
Jilly21
Message 4 of 4
I keep losing signal on tv through talk talk box
3 REPLIES 3
Message 1 of 4
Hi Jilly21
Did you check the channels directly on the TV ?
Is all ok now ?
Message 2 of 4
Connect the aerial directly to the TV bypassing the box and test for a couple of hours with different channels to see if they are weak or breakup.  This will help test the aerial signal to see if there is an issue with the aerial or the signal from the local transmitter.
Divsec
Message 3 of 4
Hi @Jilly21 a couple of obvious suggestions.
Have you checked all the connections are secure?
Do you get Freeview programmes with aerial plugged into the TV directly?
your post has been escalated and you should hear soon.  In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
