Tv set top box blue light?
Newby53
Message 4 of 4
Tried to connect my new tv top box but getting solid blue light error.
any ideas ?
3 REPLIES 3
Message 1 of 4
Does anything show on the Tv when you turn the box on ?
Have you checked the TV is set to the correct source channel so the aerial message is not from the TV itself ?
Newby53
Message 2 of 4
The tv hub. When connected the light flashes white then steady white then flashing blue then and finally sold blue. All in a few seconds. The message then says the Ariel is not connected but it is
Message 3 of 4
Is this the 4K TV Box or TV Hub ?
Compare our TalkTalk TV Boxes - TalkTalk Help & Support
