Tv
Annie84
Message 3 of 3
My tv box has stopped working am I able to get a new one . I have tried unplugging everything there is no response at all , have checked all leads .
Message 1 of 3
Hi @Annie84
If you can tell us which Box you have, we can then give the correct advice.
Message 2 of 3
Which box do you have?
If it's a YouView recordable box these are no longer available, and are approaching end of life. TalkTalk no longer provide boxes that record either.
If the box totally dead or does it switch on but no further?
If you get power, have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but it's the only thing left to try to restore the box, if possible.
Hope it works but if not and you'd like a box that streams and has up to date apps, then you will need to phone to discuss this.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
If you have a 4k or TV hub, and not a YouView recordable box then post back and we can advise further. Thank you.
Anonymous User
