Using 4k box
Geordyboy1
Message 7 of 7
Just started using 4K box since youview went out of use. Problem is when watching any catchup programs it keeps switching to a current live channel. Ok it’s soon switched off and then back to the catchup program, back by me. I have tried a hard reset in which I then have to put all the channels back up via passwords etc. it’s getting a bit of a pain in the but to have to do this. Apart from going to another provider what an I do. Please.
6 REPLIES 6
Message 1 of 7
The OP sent me a PM this morning, so all has now been resolved.
Message 2 of 7
@Karl-TalkTalk the OP has started 2 new threads (in moderated) and sent me a PM as if I am you stating still happening.
They seem reluctant to post back here so am doing so on his behalf.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don’t worry there are plenty of ways to reach out if you need to speak to TalkTalk directly if you do not obtain the answer you require.
Please see the pinned post at the top of each forum page for a link.
Message 3 of 7
Hi @Geordyboy1
Is this still happening ?
We can swap out the box also, to see if it is specific to that box ?
Message 4 of 7
Thanks for clarifying.
I've not seen that happen. One extra thing to try is rebooting your router in case there is something there causing an issue while watching catch-up.
Staff are not back until Tuesday so please let us know how you get on.
Geordyboy1
Message 5 of 7
Thanks for coming back.  The box is the Netgem 4k box
Access the catchup via apps. It seems to be More4 as it the one used the most. When it switches it goes to a live station not to a live program on 4
I have also done the switch on the side of 4k box and done the 5 presses. It does not do this regular but it is still annoying
thanx
Message 6 of 7
Which box do you have? The Netgem 4k box or the TV Hub?
How are you accessing the catchup apps? Directly via the app, or via the programme guide?
Is this affecting all catchup apps or one in particular?
When it switches back to live TV is the programme you are watching via catchup being broadcast too? If so are you certain it's switching back to transmitted live channels and not the live function within the app itself?
Normally a hard reset is the means to clear these types of issues but you have tried this, so trying to establish a bit more info so more advice can be given.
