Voice talking over programmes on tv
Rusty8
Message 4 of 4
When watching soaps on tv there is a voice commenting describing what is happening how do I turn it off
3 REPLIES 3
Message 1 of 4
Hi Rusty8
Did you manage to turn off Audio Description ?
Message 2 of 4
You should also be able to turn this off within the settings menu.
This again varies by box.
Message 3 of 4
It's the audio description.
There is usually a button on the remote labeled AD or something similar.
Search for your box remote on this site and there is a description of each button shown if you can't find it.
