freeview channel lsting several channels missing freom
Satty1
Message 9 of 9
freeview channel lsting several channels missing freom trhe listing shows channel 1 then 2 then 29 but all channels finwe on tv but can onmly be accessed by pressing no on remote
Alan Sattenstall
8 REPLIES 8
Bwarby
Message 1 of 9
Mines been doing exactly the same thing..I reported the problem a fortnight ago... I've retuned two or three times.. 1st retune lasted a week.. 2nd time I did it I reset the box completely back to default and its lasted until today.. only BBC channels 1 and 2 then 29 and then up in the 200s.. was told by support they'd raise the issue with Netgem..it's a Netgem 4k box .. lost all my recordings and schedules both times.. not heard a thing off anyone.. about ready to cancel as I'm out of contract now..
Satty1
Message 2 of 9
weird all resolved itself,had cto do nothing,wonder what caused that
Alan Sattenstall
Message 3 of 9
This is usually straght forward.  pressing the button 5 times will initiate a full factory reset.  You can then set the box up like a new box.  If this fails to resolve the issue then the next step is to swap out the box.
Satty1
Message 4 of 9
not having done thhis for a long time is this streaightforward,any advice dont want to lose all my channels,nothing recorded anyway
thanks
Alan Sattenstall
Message 5 of 9
Can you reset the box by pressing the button on the side 5 times.
set the box back up and retune and see if that clears the issue.
Message 6 of 9
Thanks for confirming.
Support Staff are back tomorrow so will hopefully be able to resolve for you.
Satty1
Message 7 of 9
box is netgem n 7950 t2c 8 talk talk 4k, on the channel listing are n1,2 ,9 ,23 etc missing 3,4,5 etc but all these channels are ok on tv,done a rescan several times awith no change.no problemw iwth picture on any channwels
pictures are all fine but only way to acxcess say channel 5 is to press 5 on remote and woks fine mbut says locked cannot display listing
is that enough
Alan Sattenstall
Message 8 of 9
Which box do you have please so we can offer further advice, such as retuning or resetting the box.
When you say the channels are ok on your TV, have you clicked on any of those channels that are missing on the box? If so, is the picture clear or do the channels break up at all?
The weather is also affecting signal quality in various regions, so it may be an added issue.
If you can let us know what you have tried and the box staff can look into.
Thank you.
Ps
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
