on 06-08-2024 07:59 PM
I'm being charged for a boost at £12 relating to UK calls but when I look up boosts there's no way for me to turn this off. I only seem able to add more boosts. I don't have a landline phone, I don't need or want this and would like to switch it off.
I've been unable to find an email address or a "contact us" section to be able to speak to a TalkTalk employee. Can anyone help?
Thanks!
on 22-12-2024 04:35 PM
Start your own topic, or contact customer services directly. Either way, they can sort this out for you.
on 22-12-2024 04:28 PM
I have also noticed I am being charged £16 per month for a service I do not use and which I can not turn off. We dont use the landline for calls and dont even have a phone to attach to it. Please remove from my account.
on 08-08-2024 12:45 PM
Hi CheerfulKoala
You had the calls boost free for 24 months when you last renewed, that discount has now expired and it is now chargeable.
I will remove the boost as I see that you don't use the phone, be aware that any calls that you do make from now will be chargeable, if the boost has been charged in advance a credit will appear on next months bill.
on 06-08-2024 10:13 PM
I suspect at sometime in the past you took up an offer with TalkTalk which included an Anytime Calls Boost. If you didn't use that, then you would have probably noticed less that when your initial offer period expired any new broadband deal would not include calls. And as @Gliwmaeden2 said there has been a long-standing issue of not being able to remove it via My Account.
You can contact customer services as suggested, or the support team here can remove it for you.
on 06-08-2024 10:02 PM
I suggest concerns@talktalkplc.com I just used to make a complaint. Firms like TalkTalk who are hard to communicate with are really annoying and a good reason to switch to a provider offering better customer service.
on 06-08-2024 08:17 PM
03451 720088 from 9am - 7pm or use Chat, @CheerfulKoala.
There's been a fault with this over the past couple of years, so you need to ask them to remove it manually for you. No idea why it's not been fixed....
Contact information:
