Can't create VPN to work from home
tlktlkuser501
Message 14 of 14
I set up a VPN to connect to my work network in order to work from home, I was able to get everything set up until I got to the stage to log in to the VPN and it couldn't connect to the work network, I can't ping the work network and receive a response either. A colleague told me he had a similar issue with setting his up, he's a talktalk customer on the same router as I am and was told he had a firmware update pushed to his router and it fixed his issue. I tried to call phone support but was sent generic info more tailored to checking your actual internet works so hoping someone here has an answer.
13 REPLIES 13
Message 1 of 14
I'm glad to hear this and thanks for confirming 🙂
Message 2 of 14
Thanks for the feedback, belated though it is.  🙂
tlktlkuser501
Message 3 of 14
Apologies for such a delayed reply but this did resolve my issue should anyone be facing a similar issue
Message 4 of 14
Hi tlktlkuser501
I have checked and I can confirm that the router has the correct firmware version with the VPN fix.
tlktlkuser501
Message 5 of 14
Hi Michelle, I've restarted my router and will check if it worked when I'm home from work but I did reset my router the other day after the firmware update was pushed and didn't seem to have an effect but will update you once I'm home
Message 6 of 14
I'm sorry to hear this. Could you try powering down the router and then try connecting again please.
Message 7 of 14
Hi Karl, unfortunately doesn't seem to have fixed the issue
Message 8 of 14
All done now, please give the connection a test.
Message 9 of 14
Firmware being pushed now.
Message 10 of 14
Hi, sorry for delayed reply but yes that would be perfect thankyou
Message 11 of 14
got the details here, is it OK to push the firmware now ?
Should take around 5 minutes.
Message 12 of 14
Hi Karl, thanks for the quick response, have updated that info
Message 13 of 14
Add your home phone number or account number to your 'Community Profile' and I'll take a look.
